1997 Honda Accord SRS light
167,000 MILES • 6 CYL • FWD • AUTOMATIC
MBASSET
When replacing the battery, the SRS (airbags) light went on, and will not shut off. I had it reset by a Honda dealer, only for it to go back on.
Do you have any idea what I should do?
How can I disconnect it if I can't shut it off?
May 26, 2010 at 7:37 AM
  • 31,937 POSTS
Hi there.
Honda should have read the code and advised on what repair is require to fix this problem, i would go get them to do the read, they should have done this in the first place.
mark (mhpautos)
May 26, 2010 at 10:13 AM
MBASSET
723505 SRS input
"retrieved codes 08-5 SRS unit failure re-set computer
should light come back on, will require SRS unit $941.24 parts and labour plus tax"
As a result of the battery being replaced????
May 26, 2010 at 10:41 AM
  • 31,937 POSTS
Hi there,
I would be getting Honda to re check the findings, but in the event of a voltage spike when the system was re activated with the battery replacement, you may have damaged the unit, i would first get this confirmed first as it is a lot of money.
mark (mhpautos)
May 26, 2010 at 11:14 AM
