1997 Honda Accord squeeking sound
1997 HONDA ACCORD
94,000 MILES • 4 CYL • FWD • AUTOMATIC
DAVE6727
  • 13 POSTS
my front right side has a squeeking sound every time u hit a bump. there is no popping sound or clicking. could something need some grease? if so where?
thanx
Nov 29, 2008 at 8:38 AM
F4I_GUY
  • 3,302 POSTS
Could be several things.
Does it also happen with you turn the wheel or turning? If so, you may have a dry balljoint on your hands.
If its soly when its over bumps it may be a stabilizer link bar or the actual bushings for the sway bar itself (unlikely however)
Can you re-create the noise in the driveway by bouncing the front suspension up and down? if so, have a friend bounce it up and have a listen with a stethoscope to which part is squeeking. Could be a shock, balljoint, endlink, control arm bushing, etc.
Nov 29, 2008 at 8:53 AM
DAVE6727
  • 13 POSTS
yes, when i push the front right side of the car up and down, the sound is heard.
it is not heard when i turn the wheel.
Dec 1, 2008 at 5:29 AM
F4I_GUY
  • 3,302 POSTS
Great, should make for an easy diagnosis then.
Get a stethoscope and have a friend bounce the car up and down. Listen to the balljoints, control arm bushings, stabilizer links and bushings, struts, etc.
Another quick check would be, say the upper balljoint is suspected of squeeking. Sometimes if you firmly hold it together the squeeking may stop while you are applying pressure. Or you can try and spray some wd40 in there and see if it goes away.
But in my opinion, the best method is a stethoscope.
Let me know what you find.
Dec 2, 2008 at 8:31 AM
