how do you test rod bearings? Can you install them while the motor is in the car? thanks
Mar 12, 2010 at 12:39 PM
✓Experienced Mechanic
You have to mike the crankshaft journals to determine the correct undersize bearings, yes it could be done with the crank still attached-cleanliness here is very important otherwise you defeat the purpose
