1997 Honda Accord rod bearings
1997 HONDA ACCORD
168,557 MILES • 4 CYL • 2WD • AUTOMATIC
CBPXT5
how do you test rod bearings? Can you install them while the motor is in the car? thanks
Mar 12, 2010 at 12:39 PM
You have to mike the crankshaft journals to determine the correct undersize bearings, yes it could be done with the crank still attached-cleanliness here is very important otherwise you defeat the purpose
Mar 12, 2010 at 1:50 PM
