1997 Honda Accord Replacing the air filter
15,800 MILES • 4 CYL • FWD • MANUAL
SLOBJONES
I'd like to replace the air filter on my 1997 Honda Accord.
However, the front part of the air filter housing is blocked by a plastic exhaust that appears to fit into a pipe.
This plastic piece must be removed so I can remove the air filter housing cover, but I see no way to remove the piece other than to yank it out.
What's the safe and correct way to remove this plastic piece?
Thanks.
Sep 14, 2008 at 11:40 AM
KHLOW2008
  • 41,812 POSTS
Hi slobjones,
It is plugged in and if you tug at it, it would come off.
Sep 18, 2008 at 2:40 AM
SLOBJONES
Thanks for that.
I was able to remove the plastic piece, with a little wiggling.
Had to move the battery out of the way as well, but after that, I was able to get to the air filter.
Sep 18, 2008 at 5:50 AM
