1997 Honda Accord Radio and lighter dont work
13,000 MILES • 4 CYL • 2WD • AUTOMATIC
IMNYC
I have the same issue. can you please guide me where the fuse box is located. if i didnt find any blown fuse, what other steps to be taken to resolve the issue. Thanks.
Oct 1, 2008 at 2:58 PM
WES1
  • 7 POSTS
This is a very big common problem with all accords 94-97. It is bad wiring. If it is just your radio and cig lighter and indiglo light around cig lighter and small light in ashtray then you may be able to remove your console, remove the trim around radio and look for a bad wire. If it is in your instrument pannel it is going to be very hard. I would suggest getting a volt meter and looking for a problem behind radio especially if there is an aftermarket radio installed. If this doesn't work or you need more info post again and I will try to help.
Oct 8, 2008 at 10:47 PM
