1997 Honda Accord Radiator Replacement
136,000 MILES • 4 CYL • FWD • AUTOMATIC
CHILIBREW24
  • 6 POSTS
I recently replaced the radiator in my 97 Accord. The check engine light has now come on. Like a bonehead, I did not label the lower tubes (not the exhaust hose) and Im afraid I may have crossed them up. However, the car has not been over heating and seems to be running fine.
any advice would be great!
Jun 29, 2009 at 11:16 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check engine light could be a coincedent.. have the trouble codes retrieved by using a diagnostic OBD-II scanner. If you don't have one, most auto part stores will use their own scanner to retrieve your trouble codes for you, free of charge. Post the code(s) you retrieve and I will follow up.
Jun 29, 2009 at 11:18 AM
CHILIBREW24
  • 6 POSTS
Will do. Thanks.
for the time being, eveything should be fine? Would having the lines crossed affect how cold the A/C should or shouldnt blow? I've noticed its not as cool as it used to be.
Jun 29, 2009 at 11:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
If you mixed the radiator hoses up, you would know it.. Yeah driving will be fine, probably just a sensor or something starting to fail that is throwing the engine code.
Jun 29, 2009 at 11:28 AM
CHILIBREW24
  • 6 POSTS
its not the hoses. I got the intake and exhause hoses. Its the smaller lines at the bottom of the radiator just left of the lower hose.
Jun 29, 2009 at 11:35 AM
BLUELIGHTNIN6
  • 16,542 POSTS
So you think you mixed up the tranny fluid cooler lines (ATF cooler hose) ?
https://images.2carpros.com/forum/automotive_pictures/261618_0900c1528003a197_1.jpg
Jun 29, 2009 at 11:40 AM
CHILIBREW24
  • 6 POSTS
Correct! those are the ones in question but I dont know if I crossed them or not
Jun 29, 2009 at 11:43 AM
CHILIBREW24
  • 6 POSTS
Correct! those are the ones in question but I dont know if I crossed them or not. How would I know if I did?
Jun 29, 2009 at 11:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
After driving it, does the ATF smell hot, burnt?
CHILIBREW24
  • 6 POSTS
nope. I havent noticed anything odd outside of the engine light and the A/C not blowing as cool. But then we're in the middle of a heat wave here so it might just feel that way.
Jun 29, 2009 at 11:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like you got it correct then.. and those hoses have nothing to do with the A/C, they only cool the tranny fluid.
Jun 29, 2009 at 12:03 PM
