1997 Honda Accord pulls to the right
TEM1953
Steering problem
1997 Honda Accord 4 cyl Two Wheel Drive Automatic
hello! my car was in an accident several yrs ago right front damage. since then car pulls to the right. an alignment shop said the engine mount needs to be moved about 1/2 inch to correct this problem and the alignment is not the answer. i can't seem to find anyone who knows about fixing this problem. i have gone thru a few tires already front right wear down rather fast. thank you! hopefully there is an answer to this. tom. 561-7902479.
Sep 21, 2010 at 8:34 AM
F4I_GUY
  • 3,302 POSTS
Do you have a sheet with your alignment angles on it? I'd be curious to see them. You may have just a bent steering knuckle or something you might have to change. But without seeing the angles, I won't be able to tell you.
Sep 21, 2010 at 10:52 AM
