I have just had my 97 Honda Accord serviced. The repair shop replaced both of shafts due to the CV joints problems and then did alignment service. They also did the timing belt and replaced two power steering and alternator belts additionally. The shop said two belts are cracked.
After driving for a test, I found the following problems and probably will back to the shop. I did not have those problems before having the car serviced. Can you tell me what the problems look like?
1) Clunk sound from left or right wheel when turning the drive wheels ALL THE WAY to the left or right. But, after turning the car several times, the clunk sound seems going away. Is it a problem?
2) In front of the passenger side comes an uneven, inconsistent click sound when driving for a while.
3) Whirring sound from the engine that gets worse when driving for a while and engine speed increases.
Can you diagnose three car repair problems above? Thank you for your answer.
Feb 28, 2010 at 1:05 PM
