1997 Honda Accord Noises from the Rear of the Car
265,500 MILES • 6 CYL • FWD • AUTOMATIC
COLIVER29
I have a noise coming from the rear of the car. I can hear it when the car is going slow. It makes this sound when I go forward and in reverse. Sometimes I believe it sounds like a knock, other times it sounds more like grinding. Is this expensive to fix?
May 13, 2009 at 1:29 PM
  • 31,937 POSTS
Hi there,
Check that the brakes are ok, check all rear suspension attach points are tight and check for any leaking around the strut, if in doubt get a mechanic to inspect and report for you.as for cost this will depend on what the problem is.
Mark (mhpautos)
May 13, 2009 at 1:46 PM
