1997 Honda Accord Noise in Transmission
1997 HONDA ACCORD
156,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAY HORINE
Recently changed CV Joints. When I first get in car in the morning and put the car in reverse I here a fairly loud clunk when the transmission engages. this only happens in reverse. This does not happen once the car is driven, Nor does it happen when I put the car in Drive, just reverse.
It use to do this in Drive only and not reverse. However when I recently changed the CV Joints I rotated the tires by hand to check clearance issues with brake lines and it changed from happen in forward to happening in reverse only.
Any ideas?
Thanks
Sep 3, 2008 at 5:04 AM
KHLOW2008
  • 41,814 POSTS
Hi Ray Horine,
I would suggest checking the CV inner joints for wear and lack of lubricants.
Sep 6, 2008 at 4:02 AM
RAY HORINE
Thanks for the feedback.
I had just replaced the CV Halfshafts prior to the noise happening. Got the half shafts from Autozone and installed them. I could not tell if the CV joints were pre-lubricated since the CV boots were already installed. I asked if Autozone if they were lubricated and they said they were. But now I question this.
Have you ever run into this???
Thanks
Sep 8, 2008 at 2:24 AM
KHLOW2008
  • 41,814 POSTS
Hi Ray Horine,
I would trust Autozone. If both shafts had been replaced, I would check the lower arm ball joints and bushes, front engine mounts and steering linkages.
Sep 9, 2008 at 12:09 AM
