1997 Honda Accord MAP SENSOR
129,000 MILES • 6 CYL • FWD • AUTOMATIC
RUSS F
WHILE DOING OTHER WORK ON THE CAR I UNPLUGED THE NAP SENSOR AND DID NOT PLUG IT BACK IN AFTER RESTARTING IT ,THE CECK ENGINE LIGHT CAME ON CODE READ PO108 MAP SENSOR PLUGED IT BACK IN LIGHT IS STILL ON WILL THIS RESET ITSELF OR DOES ITNEED TO BE RESET
Sep 7, 2010 at 6:27 AM
SATURNTECH9
  • 30,868 POSTS
The best way to reset it is to use the scanner you read the code's with.But the light will go out eventually.
Sep 7, 2010 at 6:37 AM
