Radiator Leaking Anti-Freeze
BLAKEWATSON
Not all the time several times my 97 honda accord ex after running/driving down the road for 10-15 minutes, i will get out of my car and anti freeze will be leaking fast and drip from the radiator. temperature gauge shows average. heating system in car works. You can also smell the radiator pretty well.
Nov 4, 2008 at 2:49 AM
SQM
  • 6,383 POSTS
Are you able to see where the leak is coming from?
A coolant leak can come from several components. It could be the radiator, the hoses, thermostat housing, water pump etc.
You need to visually check to see if you are able to observer where the leak is form.
Here are couple of helpful articles to get you started:
https://www.2carpros.com/articles/coolant-leak-symptoms
https://www.2carpros.com/articles/radiator-pressure-test
Aug 4, 2021 at 2:29 PM
