1997 Honda Accord Heater Blower
19,400 MILES • 4 CYL • 2WD • AUTOMATIC
MMONDELLO
I am trying to determine what the issue is as to why my blower motor stopped working, I have checked the main fuse panel under the hood and the one in the interior. I have removed the blower motor and tested and find that to be working fine. I have also replaced the Blower Resistor with a new one. I took the dash apart to check the fan switch and that also seems fine. When I tested the wiring to the blower assembly it appears there is power evident. Is there anything else that should be checked?
Mar 15, 2008 at 8:16 AM
BMRFIXIT
  • 19,053 POSTS
Check grounds and check blower motor relay
in under dash fuse /relay box
Mar 15, 2008 at 8:24 AM
