1997 Honda Accord Head Lights
191,000 MILES • 6 CYL • FWD • AUTOMATIC
ALPACA1123
I replaced the switch in the steering column and everything worked fine. A Couple days later the lights went out again. I stopped to turn my emergency flashers on, and back came the head lights. They stayed on long enough to get me home.
However, everytime i drive the car the head lights turn off. Sometimes they will come back on -then go off again and usually stay off.
* Note when head lights go off, the running lights on the car still work *
Oct 8, 2009 at 2:14 PM
KHLOW2008
  • 41,812 POSTS
Hi alpaca1123,
When the headlight fails, test if you have battery voltage at both headlight fuses in underhood fuse box. If voltage is not present, the headlight relay is bad.
Oct 10, 2009 at 6:08 AM
