1997 Honda Accord Front End Squeaks
155,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAY HORINE
I had a squeaking noise in the front end when I would push down on the front of the car. I replaced the struts but I still have the squeaking noise when I go over a bump or push down on it.
Could the problem be the lower ball joints? Or Upper ball joint?
Thanks in advance for the help.
Aug 18, 2008 at 4:57 AM
KHLOW2008
  • 41,812 POSTS
Hi Ray,
You already got the diagnosis correct, either upper or lower arm bushes or joints and you need to pinpoint the source yourself, we are unable to do it from cyber space.
Aug 19, 2008 at 3:19 AM
