1997 Honda Accord engine oil is leaking in the spark plug?
175,000 MILES • 4 CYL • 2WD • AUTOMATIC
JNPALAFOX
i have replace valve cover gasket and O rings and it still leaks, used to be in one spark plug then two and now is three of them.
Dec 9, 2009 at 11:32 AM
HONDA TECH 1818
  • 536 POSTS
The rocker arm seals needs to replace, it is between the rocker arms and the cylinder head.
http://www.2carpros.com/topics/engine-mechanical/rocker-arm
Dec 9, 2009 at 12:00 PM
