1997 Honda Accord engine light on and transmission slipping
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
LYNNDADDY
My engine light is on and the transmission is slipping a code P0740 (P740) came up. Any Ideas?
Aug 10, 2008 at 2:35 AM
KHLOW2008
  • 41,812 POSTS
Hi lynndaddy,
P0740 = malfunction in lockup system.
Check for loose wire connections to lockup solenoids.
Is the ATF level correct and trans throttle cable adjusted correctly?
Aug 10, 2008 at 4:05 AM
