HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Engine
Symptoms
Idle Low
SPONSORED LINKS
1997 Honda Accord Engine idle RPM low when AC is on
MYACCORD123
MEMBER
1997 HONDA ACCORD
Air Conditioning problem
1997 Honda Accord 6 cyl Two Wheel Drive Automatic 140K miles
when idle and when AC is on, the RPM is about 200 to 300, and the engine is rough and shaking. What is the problem? Thanks
Friday, August 6th, 2010 AT 2:37 PM
KHLOW2008
MECHANIC
Hi myaccord123,
The Idle Air Control valve is either stuck or colgged internally.
Get it cleaned together with the throttle body and idle adjust screw passage and readjust the idling speed.
SPONSORED LINKS
Sunday, August 8th, 2010 AT 9:31 AM
Please
login
or
register
to post a reply.
Related Engine Idle Low Content
Intermitent Problem With Car Dying At Low Idle
1986 Honda Accord Dx 2.0 2 Bbl Car Sometimes Dies While At Low Idle. When You Start The Car And Set The Choke It Runs Fine At High Idle...
Asked by
mdtroy
1986
HONDA ACCORD
2003 Honda Accord 2003 Honda Accord Low Idle / Stall
My Accord Will Occasionally Begin To Idle Low, 400-500 Rpm, And Has Now Stalled While Stopped At A Light 3 Times. After The Stall The...
Asked by
2Sure
1 ANSWER
2003
HONDA ACCORD
Engine Misses At Low Idle
I Have A 1992 Honda Accord Lx With 175,000 Miles. I Have Replaced The Cap, Rotor, Plugs, Wires, Oxygen Sensor, Fuel Filter, And Air...
Asked by
anthonydgravitt
1 ANSWER
HONDA ACCORD
Low Idle, Rough And Stall
I Have A 1995 With 97000 Miles On It. Its A 5 Speed. Recently It Begin To Idle Low. While Its Idling Low Its A Little Rough And Stalls A Bit...
Asked by
mkirksy3
1995
HONDA ACCORD
High/low Idle
I Have A 1997 Honda Accord - 2 Wd, 4 Cylinder Engine, 121,000 Miles. Over The Last Week, When Putting The Car Into Park After Driving...
Asked by
Adam Saperstein
HONDA ACCORD
VIEW MORE
SPONSORED LINKS
Vacuum Leak
Vacuum Leak Test and Repair
Vacuum Leak Symptoms
Online car repair manuals
