2003 Honda Accord 2003 Honda Accord Low Idle / Stall
205,000 MILES • 4 CYL • FWD • AUTOMATIC
2SURE
My Accord will occasionally begin to idle low, 400-500 rpm, and has now stalled while stopped at a light 3 times. After the stall the engine will start, but will not idle, and i have to keep pushing the accelerator to prevent it from stalling again. This lasts until I get it up to speed for a while, then seems to be ok again.
I had the local dealer look at it each time. The second time they replaced the EGR valve, but that didnt help. They are now telling me it is the computer.
The check engine light never came on until the third time, and they told me it reported a low idle error ( i dont know the codes )
What else can I make sure they have checked before jumping into replacing the computer? What are the other more likely causes? I have seen many times that a computer failure is very rare.
Jul 2, 2008 at 3:09 AM
KHLOW2008
  • 41,812 POSTS
Hi 2Sure,
Check the throttle body and IAC valve. Most probably they are clogged and is not providing enough air flow during idling. Some carb cleaner should do the job.
Valve clearances that are too tight will also cause the problem.
Jul 2, 2008 at 4:39 AM
