1997 Honda Accord Dashboard light
90,000 MILES • 6 CYL • FWD • AUTOMATIC
TN1901
The dashboard lights isn't working so its very hard to read the meters at night. I've checked the fuse and took the dashboard apart to check connections and light bulbs. I cannot find the problem. Is there a relay that could mess this up? Is it the dimmer switch? If its the switch, how can I test it to be sure?
May 16, 2008 at 10:53 AM
BMRFIXIT
  • 19,053 POSTS
U have checked the bulbs !
turn light on and then check fuses
as u may over looked one
also u have the switch and dimmer to check
I would check fuses again if bulbs ok
May 16, 2008 at 10:58 PM
