1997 Honda Accord CV Axle
SALEAGLE
Suspension problem
1997 Honda Accord Automatic
I've looked on line and one side is approx $52. What would a fair price for a garage to charge for installing one side or both (Located in Colorado Springs) ?
Also, if I have one side replaced, should I do the other at the same time ??
Thanks so much for your time.
Nov 2, 2008 at 3:10 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It is always a good idea to replace both sides at once seeing as how, if one has failed then the other is likely to fail shortly as well. Prices vary from shop to shop of course, but labor will probably run from around $200 - $500 depending on location and if you're getting both or just one.
Nov 2, 2008 at 3:46 PM
