1997 Honda Accord coolant leaking
208,000 MILES • 4 CYL • FWD • AUTOMATIC
ARMINDK
Sometimes when the car is left off for a couple of hours coolant leaks from the head gasket area and its in the corner of the engine close to where the water pump is. The weird thing is that it mostly leaks when the engine is off or is cold and it has little to no leak when the engine is hot and running. Could this be from the head gasket or the water pump?
Sep 8, 2008 at 3:33 PM
ROB2008
  • 258 POSTS
You may need to have it pressure tested if you don't know the exact location of the leak . .
Sep 8, 2008 at 3:49 PM
