1997 Honda Accord clutch
136,000 MILES • 4 CYL • FWD • MANUAL
BILL VANKOMEN
my son parked the car and said the clutch was fine, when he went to use it the next day the clutch pedal went to the floor, (it had no ressistance) i (dad) put the car in the garage and after looking on the internet and asking quite of few mechanics replaced the master cylinder on the firewall, this did not fix it. i replaced the slave cylinder and tried to bleed the system and it still did not work, if im not mistaken after pumping the clutch for sometime, the clutch should have some resistance and get better through bleeding the system, the system will not bleed after a lot of pumping of the clutch. i went to the master cylinder and took the screw out of the side of the cylinder and very little fluid "if any" is not in the system. do i have to prime the system some how? or do i have a air lock in the hydraulic lines?
Nov 15, 2008 at 3:41 PM
  • 31,937 POSTS
Hi there,
You can't pump up a clutch like a brake pedal, the master cylinders are designed differently. You have to hold down open the bleeder, allow air ? fluid to escape, close bleeder, lift pedal, you have to do this till the air is bleed out, don't pump the pedal as it will get you know where.
mark (mhpautos)
Nov 15, 2008 at 7:09 PM
