1997 Honda Accord bad valve gasket set?
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAMION8807
About a year ago i purchased a 97' honda accord, shortly after purchasing it i noticed oil on the plug wire ends. I went ahead and replaced the Valve gaket set, plugs and wires. It seemed to work okay. Now the problem has a occured again. I wasn't sure what could be wrong, I replaced the pvc valve with the kit. Should i look at vaccuum hoses for a clog? The car also has a slight sputter that the dealer said was just timing, and that it wouldn't cause it is this the case? Any help is appreciated.
Jun 10, 2008 at 6:28 AM
KHLOW2008
  • 41,812 POSTS
Hi damion8807,
Oil in the plug cylinder, could cause misfiring.
If your engine is the F series type, under the rocker holders are 4 seal rings. They could cause the leakage also.
Jun 10, 2008 at 6:44 AM
