1997 Honda Accord all indicator lights on but engine not st
LP65
1997 Honda Accord 4 cyl 80000 miles
It happens once every other week or so-It happens normally in the morning, the first ignition-If no push clutch hard enough,the problem mentioned above happens. Only one loud "scratching" sound and all lights on the panel light up. Then I have to try three or four times before it will finally come up. I took it to my mechanic and they could not find anything wrong with the clutch. They told me they adjusted the "neutral safety sensor" but the problem remains.
Thanks for any advice!
Sep 1, 2008 at 4:58 PM
  • 75,988 POSTS
Find the clutch switch on the clutch pedal bracket disconnect the switch and jumper the connector and see what happens.
Sep 1, 2008 at 5:05 PM
