1997 Honda Accord air conditioner stop cooling
196,000 MILES • 6 CYL • FWD • AUTOMATIC
WJACKSON
The air blows cold but afte about 30 minutes it stops blowing cold and blows luke warm air. If you turn the air off for 30 min then it usually begins to blow cold air again. The air is cold when it is blowing.
Your advertisement says "Free" so now I see that if I don't pay you something I get a second rate answer?
May 22, 2010 at 5:33 AM
  • 75,988 POSTS
Your problem is a very complicated issue your most probable cause here is the AC could be freezing caused by air and moisture that turns into ice blocking off the orifice tube. Could also be the pressure cut-off switch, magnetic clutch, relay, and the HVAC module.
Before you condemn us why don't you give us a chance to assist you instead of being judgmental there's only so much we do
May 22, 2010 at 6:13 AM
