1997 Honda Accord A/C
TERESA622
1997 Honda Accord 4 cyl Front Wheel Drive Automatic 186k miles
The honda I have ac /blows but no cold air. Its full of free on and the hose is cold. the compresser is kicking on. it was in a small collision prior to this problem.
Aug 25, 2010 at 1:12 AM
WRENCHTECH
  • 20,760 POSTS
Try totally pinching off one of the heater hoses to determine if it is a heat control problem or not.
Aug 25, 2010 at 1:42 AM
TERESA622
My hubby says the compresser doesnt turn on, however the A/c lines are cold and only blows hot air
Aug 25, 2010 at 11:04 AM
WRENCHTECH
  • 20,760 POSTS
[quote:1e70901c3b="teresa622"]My hubby says the compresser doesnt turn on, however the A/c lines are cold and only blows hot air[/quote:1e70901c3b]
Sorry, not possible
Aug 25, 2010 at 11:16 AM
TERESA622
Ok, about that 97 Honda accord everything is working on the a/c. compresser everything but it is blowing Hot air.
Aug 25, 2010 at 2:59 PM
KHLOW2008
  • 41,812 POSTS
Hi teresa622,
If the compressor is working and the pipes are cold, the A/C system is working correctly.
Check the air mix door cable adjustment. If the linkages are out of adjustment or dislodged, only heated air would blow out of the vents.
Sep 10, 2010 at 3:57 AM
