1997 Honda Accord 02 Sensor
127,000 MILES • 4 CYL • FWD • AUTOMATIC
GYANNA
I have a Honda Accord that is running bad when it warms up. I changed both 02 sensors and the car is running bad from when you crank it up. After replacing the sensors I did a soft reset on the car by disconnecting the positive lead from the battery for about 30 secs. It still does the same thing. Not sure what else could be wrong with the car. I am trying to get the tool to read the computer. At first the check engine light would stay on. After the reset it went off then started flashing. Not sure. I would appreciate some help. Thanks
Sep 25, 2010 at 10:30 AM
  • 75,988 POSTS
Go to Autozone and have it scanned for free-This is your starting point finding out what's causing the CEL to come on.
Sep 25, 2010 at 7:48 PM
