1997 Honda Accord
JOHNNY DELEON
  • 1997 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 137,000 MILES
While driving my car was stalling and then died. I can turn it over but it has no power?
Friday, March 19th, 2010 AT 3:26 AM
Did you have a check engine light on? If not, do below to determine whether it's fuel or spark.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, March 19th, 2010 AT 4:39 AM
