1997 Honda Accord
200,000 MILES • 4 CYL • FWD • MANUAL
JAREDZ.CURTIS
while idling rpms jump up and down not all the time just some times cold or hot
Jan 25, 2010 at 9:32 AM
  • 75,988 POSTS
Try cleaning out the idle air control valve and see what happens.If it doesn't work check and test the following below:
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 25, 2010 at 9:57 AM
