1997 Honda Accord
201,000 MILES • 4 CYL • FWD • AUTOMATIC
YANG
2 back and 1 front left tires are style rims tire sizes are P225/45 R18. The 1 top right is a regular honda tire P205/65 R15 can i drive my car with my wheels like this ?
Aug 24, 2008 at 11:46 AM
KHLOW2008
  • 41,812 POSTS
hi yang,
Based on the tire sizes, they are different by 1.5 ins in diameter but ie when tires are new. Used/worn tires would be different.
Difference is not much and theologically it can be applied, but the threads and surface contact are different so braking efficiency would be different.
I would not advise using it, only as a temporary measure as if you are using a spare tires.
It you must use it, make both front tires same, put the different tires at rear left.
Aug 25, 2008 at 8:37 AM
