fans only working when AC in on. Could this be a t- stat issue?
May 20, 2008 at 2:35 PM
✓Experienced Mechanic
Hi there,
depending on the Vin No of your car the cooling fans are operated by a number of different sensors, water temp or oil temp, you will better served to ask your dealership to investigate which system you have, as it is a complex system to test as well.
