my wipers work, but when i try to get fluid nothing comes out. i don't know where the washer pump is located or what else it could be?
Dec 3, 2008 at 4:02 PM
✓Experienced Mechanic
Hi there,
The pump is located in the bottom of the washer bottle, if you can hear the pump running, check that the nozzles are not blocked, use a pin to clear them, if you can't hear the pump it may of failed.heck power to the pump and if ok replace the pump.
