1996 Honda Accord whining,grinding noise in belt driven acc
121,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVEYB363
My 1996 Accord has developed a whine in one of the belt driven units that is not involving the engine or transmission. The car runs and drives fine but the squealing,grinding noise seemms to be coming from the area of the AC compressor. Yesterday my wife came home from the YMCA(1.5 mile drive after a cold start up) with a knocking noise that sounded like a bearing knock from the car. After checking that engine was not hot nor running rough I drove the car 7 miles to the Honda dealer. The knocking noise stopped after 1 mile and the familiar squeal and grindind noise returned for the rest of my trip. Any suggestions here?
Nov 10, 2010 at 11:48 PM
KHLOW2008
  • 41,812 POSTS
Hi daveyb363,
Symptoms indicates the crankshaft harmonic damper is most probably faulty.
Start engine and note if the inner ring of the crank pulley wobbles. If yes, the harmonic damper is bad and the crank pulley has to be replaced.
If not, check the alternator/ AC belt tension and condition and adjust/replace as necessary.
Nov 11, 2010 at 12:45 AM
