1996 Honda Accord Where is located the secondary oxygen sen
1996 HONDA ACCORD
102,000 MILES • 4 CYL • 2WD • MANUAL
BEBELLES
Hello
My engine service light just pop-up and i did read the code the number is 63, PO137 i whant to repalce it but can not find the location of this sensor can you help me on this
Feb 28, 2009 at 6:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
P0137 Oxygen Sensor Circuit Low Voltage (Bank 1 Sensor 2)
Your oxygen sensors are located on the bottom of the exhaust system. Bank 1 is referring to the side of the exhaust with the number 1 cylinder and sensor 2 will be after the catalytic converter (furthest away from engine). Simply unscrew and disconnect electrical connections to replace sensor.
Thanks for using 2CarPros.com!
Feb 28, 2009 at 6:19 AM
