After my 1996 Accord warms up and the engine rpms drop, the air conditioner compressor begins to cycle on and off very quickly. I hear clicks coming from the compressor area that I think may be the clutch engaging and releasing; the compressor moves a little each time The engine shimmies alot at the lower idle speed. This began recently following a tune-up. The low side a/c pressure is around 90 psi before start-up, drops to 30 psi when the compressor is on and then moves to 45 psi when the engine is shut off. On hot days the a/c takes forever to cool the interior. I would greatly appreciate your thoughts. Thanks.
Jun 26, 2008 at 6:17 AM
