I am trying to replace my VSS and I think I have found it but I can't figure out how to remove it. My manual says to just unplug it, unscrew it, replace and repeat. However it has this metal cap on top to which the 3 pin connector is firmly attached. The is also a little metal pipe running into the cap. How do you remove the metal cap and/or the plug so that i can get to the speed sensor. Thanks
[img:73081c4344]http://www.2carpros.com/forum/automotive_pictures/200934_vss1_1.jpg[/img:73081c4344]
Jun 12, 2008 at 6:26 AM
