1996 Honda Accord Struts or no struts
105,000 MILES • 4 CYL • FWD • MANUAL
JIMMYSMITS
Does this vehcile have struts or not? A mechanic states that they are there, the manual, "With a full double-wishbone suspension, the Accord does away with the McPherson struts most other cars have these days, so you'll only be in for shocks at replacement time." I should only need shocks? How do I tell?
Thanks
Jul 14, 2008 at 4:53 AM
2CARPRO JACK
  • 11,533 POSTS
Yes your car has struts. Usually th estrut contains th espring as well, they are 2 seperate pieces that are assembled as one piece.This is why you should use a strut compressor to replace them so you can compress the spring to remove the top retainer
Jul 14, 2008 at 4:58 AM
