1996 Honda Accord squeaking
156,000 MILES • 4 CYL • 2WD • AUTOMATIC
RADIOHEADCA
My car has been making some disturbing squeaking sounds. It sounds exactly like the squeaks that would come from old bed springs. It happens when i drive over speadbumps and un-stable surfaces. The sound seems to be more noticeable on some days over others.
Apr 19, 2008 at 7:29 PM
YAM
  • 23 POSTS
It could be that you need to replace the struts on a car or shocks. But most the time it is the struts and they are just getting old . That would be my first place to look, I had the same problem with my 95 Infiniti G20 that whenever i went over bumps it would make a horrible noise in the back. Also check the muffler to make sure that it is on good or if you have a new muffler then you should be fine.
Apr 19, 2008 at 9:23 PM
