1996 Honda Accord Replacing Radiator
166,000 MILES • 4 CYL • 4WD • AUTOMATIC
FELECIAB
How can i replace the radiator if it is cracked and fluid is leaking. Do I also need to replace the thermostat
Oct 18, 2010 at 12:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
did the radiator crack due to overheating issue? if so then you will want to fix the overheating issue first then replace radiator
Oct 18, 2010 at 12:07 PM
