1996 Honda Accord radiator evaporates water at a fast pace
106,000 MILES • 6 CYL • FWD • AUTOMATIC
AHYSAH
I will check the radiator, maybe every 2 days and will find that is almot completely empty.
After adding water the car is fine but then the water will eveporate from the radiator.
The temperature gauge did go to extremely hot once, but with the radiator full the gauge stay at the middle line.
Could the engine be severly damaged with this kind of issue.
Jan 15, 2010 at 1:41 PM
BMRFIXIT
  • 19,053 POSTS
Coolant system need to be pressure checked
and also check headgasket
running engine white overheating will cause internal failure
if it hasn’t happened yet
Jan 15, 2010 at 1:52 PM
