1996 Honda Accord po302 code
183,000 MILES • 4 CYL • FWD • AUTOMATIC
JDENSLOW
I have a 96 Honda Accord with 183k and am getting a po302 code. I sometimes notice a slight misfire at 2500 rpm. Things I have done are as follows:
coil
ICM
distributer cap rotor wires and pllugs
MAP sensor
EGR
compression check
vacuum check
cleaned injectors and moved #2 to #1 to verify injector.
added Lucus injector cleaner and octane boost
filled car with 93 octane
still getting the same code and I believe I have aged about 10 years since I started this project. Have no problem with making a donation if someone can help me but have already spent over 400 bucks and not sure this is fixable. Any help would be GREATLY appreciated. This is no longer a project but a quest to succeed LOL.
Apr 21, 2010 at 11:21 AM
  • 75,988 POSTS
Inspect and test the camshaft and crankshaft sensors
Apr 21, 2010 at 10:38 PM
