1996 Honda Accord obd troble codes
1996 HONDA ACCORD
115,689 MILES • 4 CYL • 2WD • AUTOMATIC
CBPSAK
I have the following codes:-
p0715 input/turbine speed sensor circuit malfunction
p0740 Torque converter circuit malfunction
How much would it cost to repair?
Sep 11, 2009 at 1:42 PM
  • 31,937 POSTS
Hi there,
What you first need to do is have both systems inspected to see which part is at fault, normally it will be a sensor and a solenoid, the prices will vary depending on if you get genuine or after market, bet you get a few quotes from transmission specialist, but don't be surprised if they will require an inspection first, to prove the diagnosis.
mark (mhpautos)
Sep 11, 2009 at 1:48 PM
