1996 Honda Accord No Cold air
106,000 MILES • 4 CYL • 2WD • MANUAL
HENRYCA
The Air Conditioning used to blow cold air... the car has been basically inactive for the past 4 years. I finally have it on the road again and no cold air blowing anymore. The blower works of course.. but it blows hot air.
Help?
Oct 12, 2009 at 6:40 PM
BIG_JAY
  • 121 POSTS
You will need to make sure you have a full charge of refrigerant before you can test anything. Best way is to find the high and low side fittings and remove 1 of the caps and tap the valve with a key or a screwdriver or soehting small. Make sure u hold a rg over it so it does not sparay you in the face. If air does not shoot out of the fitting then go to the parts store and buy a kit to charge the ac. Most hondas take about a 1lb-1 1/2 lbs to charge them. @ 12 oz cans will be pleanty. If air shoots out very hard then please post back and I will walk you through more tests.
Oct 12, 2009 at 6:53 PM
