Raise and support vehilce. Remove axle nut, remove damper bolt and pinch bolt( bottom of strut) remove kotter pin and ball joint nut. Seperate ball joint from lower amr, push axle through th espindle assembly. Use a big screwdriver to pop the axle out of trans (use drain pan, oil may leak out) be careful of the inner seal. Remove axle and reverse to install tighten axle nut to 181 ft lbs
May 19, 2008 at 12:58 AM
