pedal goes to floor...pump pedal and hold, still goes to floor...no apparent leaks...fluid level is ok...vacuum line ok (visual inspection)...if master cylinder is the culprit, please tell me procedure to bleed system once cylinder is changed.
Oct 19, 2008 at 9:55 AM
