1996 Honda Accord Inconsistent Cold Engine Idle
JMY129
Engine Performance problem
1996 Honda Accord 4 cyl Two Wheel Drive Manual 117K miles
I have a 1996 Honda Accord, 4 cylinder, manual trans with only 117,000 original miles. In the cooler weather, when I first start the car, the idle fluctuates between 800-1500rpm. It seems cyclic. Once the engine warms the idle fluctuation ceases.
Any ideas? Thanks.
Jul 31, 2008 at 8:35 AM
BLACKOP555
  • 10,386 POSTS
i would try a new coolant temp sensor first and see how things go, if not that it is probably a bad IAC module see if you can clean it up a bit, if not it will need replacement.
Jul 31, 2008 at 10:02 AM
