1996 Honda Accord Hood Won't Latch
DJBITTNER
The hood release (inside the car) seems to be completely slack -- in other words, the hood will not latch shut. It's been really cold in Michigan lately so it seems like the cable is frozen & not retracting.
Feb 13, 2007 at 5:32 AM
BRUCE HUNT
  • 3,754 POSTS
Dan,
You don't even know the pain in the efforts it takes to repair the cable if the hood gets shut and the cable is bad. I suggest that you get a new cable for the hood and not risk that the cable is bad somewhere along the line. Just the fact that it is dragging might imply that moisture is in there and rust is probably working at the cable too.
Feb 15, 2007 at 2:26 AM
Suggested Repair
Replace the hood release cable rather than relying on a frozen or dragging cable. Moisture and rust may already be damaging it, and a failed cable is much harder to repair if the hood is closed.
Conversation Summary
The owner of a 1996 Honda Accord reported that the interior hood release felt slack and the hood would not latch shut, suspecting the cable was frozen in cold weather. The expert advised installing a new hood cable now, noting that dragging can indicate moisture and rust and that repair is much more difficult if the hood is shut with a bad cable.
