The dashlights dont flicker, when they key is turned on you can hear the fuel pump going all of the dash lights turn on like normal. When the car dies, the batt light, check engine and all the caution lights come on in the car and dont flicker
the ignition switch is good, that was replaced about 6 months ago. Without going too far in depth, is there a strong likelihood it could be a bad distributor? The reason I ask is because when it does run, for the short time it does, it does not run rough, and when the engine is revved up to 3 or 4 grand it isnt missing or back firing at all, it sounds good. One of my buddies mentioned that he was having the same kind of issues and it was a faulty distributor
thanks for your help! It is greatly appreciated!
Wednesday, July 15th, 2009 AT 1:32 PM
